We value your input!
NESTED MODULES
Gerry Leonor
i'm currently working in v9. i have a file which modules in a number of other files (PLNs) into this 'overall plan file'. my question is, is there a way to skip certain modules in one PLN and yet have another module in the same PLN appear?
AC25 | Win10 | 64Gb RAM | Intel i7 13700F | RTX 4070 Ti
https://discord.gg/XGHjyvutt8
13 REPLIES 13
Gerry Leonor
7 views and no replies...
i guess that's a 'no'???
Link
Maybe you'd like to reword the question. It's not really clear.
Link.
Gerry Leonor
hehehe...sorry
ok...
for ease of drawing on my part, i have split the project into 2 files (it has 7 tenancies) -refer to attached pic-
the horizontal tenancies are (the ones with grids) are one file, and the vertical tenancies (the ones without grids, as i haven't shown their specific layers) are in another file.
both of these files have a module which shows toilets. (you can see them arranged next to each other in the partition walls between tenancies)...
i have linked these 2 files to each other, and have skipped the modules for each link, meaning i will not be seeing the toilet modules from each other's file. as you can see the toilet amenities are not shown in the vertical tenancies.
i have a third file which encompasses both files, used specifically for site plan, roof plan, an overall floor plan etc. i know i could have just done 2 files and have one of them have the site/overall floor plan/etc, but i realised it was easier this way.
the thing is, when i want to look at an overall floor plan (showing the interiors of all tenancies) i also want to see the toilet modules for each tenancy. the thing is, in the third file i have 'skipped nested modules' for both the vertical and horizontal tenancies because if i did, i would be doubling elements shown.
long question short, is there a way to select which modules (within a hotlinked PLN file) to be skipped?
i think i made that question even more complicated
__archiben
archicad's 'module' capabilities extend only to skipping all or no nested modules.
long answer short: no.
~/archiben
b e n f r o s t
__archiben
i think you are making the process more complicated than it has to be too:
why not just have the master file which modules in the two tenancy files (skipping nested modules) and the third toilet block file? or did i completely misunderstand your complications?!
~/archiben
b e n f r o s t
Gerry Leonor
damn
i'm hoping they have more options in v10 (do they???)
__archiben
that'll be a big fat NO too!
b e n f r o s t
Gerry Leonor
a possible suggestion for the next version then...otherwise, i'd have to spend time trying to think of ways going around this problem...
__archiben
what about my suggestion above?
~/archiben
b e n f r o s t
