‎2011-11-30
04:31 AM
‎2023-05-23
02:45 PM
Rubia Torres
‎2011-11-30 04:44 PM
‎2011-12-01 04:00 PM
Olek wrote:The Mesh tool is an alternative. If you have the x, y, z coordinates, then it is possible to generate the Mesh automatically using the Place Mesh from Surveyor's Data feature, I have posted a tutorial here: CREATING A MESH FROM A TXT FILE.
Should i be using the mesh tool instead?
‎2011-12-03 07:55 PM
‎2011-12-06 12:49 AM
‎2011-12-06 03:01 PM
Olek wrote:The way to delete a Mesh point is to drag it outside the Mesh boundary. I did a quick check of the Help files and did not see this explained, so I can understand your irritation.
- can't believe there is no delete mesh point option in the pet palette..)
Olek wrote:Yes, elements must have thickness (not be planar) to work with SEO. One method is to give the Mesh a thickness: create a duplicate that is slightly lower, then trim the upper Mesh with the lower one (using SEO) so you have a Mesh with thickness that can be used for SEO on the walls. After this operation, put the lower Mesh on a hidden layer (deleting it will cancel the SEO). This technique has been discussed on this forum if you want to do a search.
I have my mesh "roof." I cant figure out how to trim walls to it. I can't do SEO because the mesh doesn't have thickness.?
Olek wrote:In AC 15, go to Help > ArchiCAD 15 Downloads, this will take you to the web page with the Goodies that includes the Mesh to Roof Tool for AC 15.
I found a "mesh to roof" goodie on the grafisoft website, but that is only for AC 14.
‎2011-12-07 02:43 AM
David wrote:I think you just need to run the latest hotfix again.
(When I added the current Mesh to Roof Add-On, I got a warning about the Add-On being older than the latest AC build, but it works.)
‎2011-12-07 03:22 PM
Barry wrote:Barry:David wrote:I think you just need to run the latest hotfix again.
The hotfix is supposed to update all goodie add-ons if I remember correctly.
