Need help
I have lost all my wall in 3D view. Walls are there in plans, elevations, sections, etc. just not in the 3D views. Have I accidentally set something to hide the walls?
1 Reply 1
Eduardo Rolon
Items to try:
1.With nothing selected go View Menu -> Elements in 3D View ->Show selected in 3D or use "Show all in 3D" option
2. Check the renovation status of the 3D window matches the Reno Status of the floor plan.
3. Select one wall in plan and do a Show Selection only in 3D (same menu as 1)
4. Check in View Menu -> Filter and Cut Element Settings that walls are checked.
5. An obvious one do a zoom extents to see if you are looking in the right direction.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
