2008-01-12 01:38 AM - last edited on 2023-05-26 12:51 PM by Rubia Torres
2008-01-12 02:21 AM
2008-01-12 02:32 AM
2008-01-12 03:56 PM
estugarda wrote:I don't believe so. ArchiCAD has always (at least since version 3) worked in floating point math not integer based units, and the models are made to (virtual) real world dimensions. As I understand it there is an internal assumption of one meter as the standard unit of measure, but I expect that this is deeply woven into the program and is not simply a "working unit" that could be altered in one place.
When I think about it, probably there is a code somewhere in *.pln file which determines the working unit...If it could only be changed...
