New Fill Failure
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2020-04-09
04:06 PM
- last edited
a month ago
Molinda Prey
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-04-09 04:29 PM
Had the same issue some days ago.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-04-09 06:15 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-04-09 07:34 PM
anto_bg wrote:Yes, it's called Linework Consolidation.
Is there a way to quickly turn the polylines into lines? I exploded them but they are still polylines and the fill still doesn't want to be created.
Even tho it is totally unintuitive to put this option in this dialog imho, but alas, once you know it...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-04-09 08:22 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-04-10 10:27 PM
I tried it in AC23 and it works for me. I also tried it in AC20 (AC21 is not installed) and it works there too, so it should work in AC21 as well.
Maybe the reason it does not seem to be working is because the "Keep Original Elements After Exploding" is checked by default so after you explode it, the Polyline is still there and when you try to select it, the Polyline gets selected, not a Line segment. Just a guess.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-04-10 10:34 PM
LaszloNagy wrote:That's what I initially did but the exploded polylines are still polyline segments (not lines) and they weren't visible in the Fill window.
You can simply select a Polyline and use the "Explode into Current View" command to convert it into Line segments.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-04-10 10:48 PM
