New Independent Detail default scale
when i create a new independent detail, it defaults to a 1:100 scale which is a bit silly for a detail. is there a way i can change this so it opens at say 1:5 ?
David Maudlin
clare:
The Detail's scale is determined by the current Plan scale, so you could set the Plan scale to the desired Detail scale before creating the new Detail.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks very much!
