Brett Brown
New Soft Insulation
Can anyone give me a clue as to how to set this up in a composite?
I'm using Insulation 1, but it is tiny and not running perpendicular to the wall skins. I have the fill oreintation set to "fit to skin". From Help it's supposed to stretch in width to match your wall width.
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
3 Replies 3
Well, it seems you know everything. First create your symbol fill (or use an existing one) and then choose this fill in your composite and set it to fit to skin.
Note that when you create your symbol fill (in Options/Atributes/Fill Types) there is a little yellow square. Thís square is stretched to the width of your composite. You might also want to zoom in or out in the preview.
Brett Brown
Cheers, re did those settings which are the defaults I think and now its works. Could have been an overnight restart which helped as well.
I don't a restart has anything to do with it, but hey, when it works, it works!
