‎2010-01-23 01:30 PM
‎2010-01-26 12:27 AM
NStocks wrote:You should probably
Now I just need to create a fill that represents timber frame wall. Could I also show the timber frame wall in 3d
‎2010-01-26 12:22 PM
Matthew wrote:Well the external walls are just like studs aren't they, where you have a exterior cladding for weatherproofing and aesthetics. Then you have the studs that actually hold everything together and for support, then insulation then plaster. I've not yet looked at timber frame construction but hopefully when I do, I can create it in CAD more accurately.NStocks wrote:You should probably
Now I just need to create a fill that represents timber frame wall. Could I also show the timber frame wall in 3dbuildthe timber frame in 3D with the beam and column tools. Fancy joinery, chamfers and other details are a bit of a chore but you probably don't need them at this point anyway. Curved bracing can be accomplished with profiles. You could also do full bents with Trussmaker. It is a bit limited but quite easy and quick.
You might also want to check out Ralph Wessel's tools at:
www.encina.co.uk/
He has a great all around modeling tool called OBJECTiVE and a full on timber framing tool called FrameWright. I don't know his educational policies but they may be surprisingly generous.
Your talk of walls confused me a bit. It sounds like tour assignment is not to use walls at all but rather to use a frame with skins and partitions. In modern timber framing it is quite unusual to use exterior stud walls at all. The preferred method in my experience is to wrap the frame with exterior panels.
‎2010-01-26 07:54 PM
NStocks wrote:In my experience here in the states the enclosure panels are typically sandwiches of insulation, lining and cladding. They may or may not have sticks in them which may or may not be the same dimensions as studs. In any case the panels are only structural in the same sense as sheathing is to a stick framed structure.
Well the external walls are just like studs aren't they...
‎2010-01-26 08:30 PM
Matthew wrote:After reading a few books, for cross referencing, I'm going to make the wall studs ( if you call the external walls studs ) 100mm x 50mm, and insulate them with Kingspan, then add cladding and lining, followed by plaster as you mentioned.NStocks wrote:In my experience here in the states the enclosure panels are typically sandwiches of insulation, lining and cladding. They may or may not have sticks in them which may or may not be the same dimensions as studs. In any case the panels are only structural in the same sense as sheathing is to a stick framed structure.
My main point is that timber framing is like heavy steel construction in that whatever "walls" there might be are not structural and so are not subject to the same constraints and construction methods as stick framed buildings.
‎2010-01-28 02:37 AM
