Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
New hotfix for ArchiCAD 10
A new Hotfix is available for ArchiCAD 10 (build 1176). This Hotfix applies to all platforms, and both commercial and education licenses. Currently, it is available for INT (international English) and USA versions, but other localized versions will follow soon.
You can download the Hotfix with the 'Check for updates...' command in Help menu. Please read the Release Notes carefully.
Gergely Kmethy
VP, Customer Success, Graphisoft
27 Replies 27
I have installed the "hotfix" per the instructions and now ArchiCAD appears corrupted on the initial start-up dialog. All the recent projects appear as just an icon. No trace of a file name or path. The button at lower right to allow you to Browse(?) or Continue (?) is either blank or has odd symbols in it.
It did not properly load one of the 3DS.apx or Quicktime 2.0 VR engine file.
It appeared to load a file and save as after that but I am afraid to get too much deeper in the project.
Has anybody else had problems with this?
I'm running XP Pro, SP2 on a Athlon X2 Dual 4800+ 2.41ghz
2gb Ram, Nvidia FX3400-256
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
A complete reinstall of ArchiCAD would not hurt. The start-up dialog is actually an add-on, that might have had corrupted someway. Reinstall will probably fix it.
Gergely Kmethy
Thanks Gergely,
A reinstall or repair worked fine.
Where are the release notes??
TomWaltz
There's a link to them on the Update page.
Tom Waltz
Does anybody else have a useless grid dialog like the one shown below? Once I have placed the grid system using Design->Grid System->Grid System Settings... I can no longer edit the grids. This is happening on every computer on which we installed the 1176 patch with the new Goodies.
We NEED to have this functionality back!
Dennis Lee
I had the same problem, solved by turning on the eye symbols in the following: options - > work environment - > tool settings dialog boxes.
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
That's interesting. I never really noticed those eye symbols before. I can't imagine when I would ever would want to turn them off.
Thanks!
Laura Yanoviak
Has anyone experienced a "slow-down" after installing this hotfix? We have a team (one Teamwork file) that has slowed down considerably since installing the hotfix (actually, there is one person on the team is not experiencing this behavior) -- any suggestions?
