New openings won't cut into plan with old to new paste
I copy and paste a plan from an older version into AC15 and new door/window openings won't cut through the wall plan but do show right on the elevations. I need to redraw the wall first and can't find any workaround.
There's 3 reasons that I can think of off the top of my head:
1. have you checked your Model view options under 'Document'?
2. Another reason the might not show is the Renovation Filter - check which option your view set is on
3. Check the Floor Plan Cut Plane Settings in your viewsets.
hope that helps...
Well Mark, it ended up as being your item 2, Renovation Filter. That saved me heaps of time. I think I should study the manual a bit more now, many thanks!
