Mario Sacco
New probabily future function "slab priority"?
It seems they are working on it.
See the disable funcion you too have on your archicad 16.
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
stefan
A long time wish of mine, to enable automatic solving of connections between slabs and walls (e.g. using the priorities already in place for composite structures). One thing that Revit does better 😉
I currently split up slabs in finishing and load-bearing part (each as a composite) and use SEO to cut out the overlaps, but this does not seem to be fully effective when performed in sections, as it only affects visible objects.
Having a "slab end" profile (similar as the wall ends) would also solve some of these problems. I remember a slab accessory tool in an older version, but not sure if that is still available (goodies?).
Archicad-user since 1998
my Archicad Book
