New project starts zoomed WAY out.
When I start a new drawing, the display is zoomed incredibly far out (like 85,000 feet across the screen). Not sure how this started. Any ideas of how to get new blank drawings to start so they are more reasonably zoomed (like 100' across)? TIA-
Richard
AC26 (since AC6.0), Win10
8 REPLIES 8
Link
Richard
Seems like either your project is millions of miles away from project zero (in which case you would have to move it back).
Or you have an element that is trying to escape the project!;-) Try turning on all of your layers, zooming extents, then in the arrow tool, hit Ctrl+A. Check if you can see anything selected near the edge of your floor plan window.
I got a 6 pack says you find something out there
Good luck.
Link.
Link wrote:
Richard
Link.
So will you be sending that 6-pack by UPS or FedEx?
There is nothing out there. This was a brand new blank drawing, created on starting up ArchiCAD. (Using latest settings, though) I believe this is a bug; reproducible, but only randomly. I did a "new and reset" and things went back to normal, and tried a few more new drawings, using the "latest settings" radio button, and zoom was okay. Not sure yet what the trigger is for the weird zoom behavior, but I guess it's nice to know we can model the state of Texas, if necessary. (I mean physically, not behaviorally.)
Richard
Link
Well if there's beer on it, I think I will need some closer inspection. Please email me a zipped PLA of it! my email address is link at archilink.net. I'll take a look at it on my next flight.
Link.
Djordje
If the last project you worked on was far from origin or was zoomed out, then this is a feature, not a bug 😉 I would always start new projects from a template (which you do have set up, right? )
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Not sure if I agree on this one, Djordje. I've had the same behavior as Richard at times (haven't bothered to pay attention to the circumstances) ... where the initial zoom level is ridiculously far out, as he says, farther than I would ever zoom...much less in the last project.
I don't recall it ever happening with a template, though ... just when I do a "new with last settings" when testing something.
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
One of the forum moderators
Djordje
Missed the smiley, huh? 😉
One more reason why you should always start new projects from a template.
Djordje
HP Omen
Yes, I agree for 'real' projects... but to clarify, are you suggesting this as a workaround until "new with last settings" is implemented properly? When I'm quickly verifying a bug or trying something for someone here on the list, 'new with last settings' should be good enough IMHO.
Do we have a wishlist item on that one? 😉
Thanks,
Link wrote:
Richard
<snip>I got a 6 pack says you find something out there
Link.
Link,
The solution just appeared: http://archicad-talk.graphisoft.com/viewtopic.php?t=6905
There was nothing out there.
Still waiting on that 6-pack....
Richard
