Non True Type font?
Jacques Toerien
Is it possible to use a non-truetype font (TTF) in ArchiCAD on the Mac? And which fonts are recommended?
I have something like RomanS in mind?
Thanks in advance?
-Jacques.
2012 13" Macbook Pro 8GB Ram, OS X 10.14.6
2010 Mac Pro 2x 6 Core 2.93Ghz Xeon, 48Gb Ram, OS X 10.14.6, RX 580
To summarize the summary of the summary: people are a problem. - Douglas Adams
I've never had any problems with Postscript or OpenType with ArchiCAD on the Mac. (PCs are another matter.)
Djordje
RomanS is an AutoCAD font; if you have AutoCAD installed (which you don't as you are on the Mac), or whoever does have it, there is a set of TTFs provided by Autodesk that matches the standard SHX (native AutoCAD vectorial) fonts.
So you should ask a friend using Windows that has AutoCAD installed to give you these TTFs, and map them in your Translator (licensing agreements permitting, of course!)
HTH
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
