Non-vertical columns
Howdy fellas,
I was just wondering how would I create a column that is on a 10 degree angle vertically? Isn't there a way to change the script or something and then save it as a seperate object?
Andrew
Use the cylinder object. The organization of the AU library won't match the screenshot of the US lib below, but you can use the 'find' function.
One of the forum moderators
Thanks very much mate, greatly appreciated.
Andrew
