Not able to expand the calculate menu
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2005-02-03 01:17 PM
‎2005-02-03
01:17 PM
regards
ashok
3 REPLIES 3
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-02-03 01:30 PM
‎2005-02-03
01:30 PM
ashok_hj wrote:Go to Options/Work Environment. You probably have the menu structure set to Basic. Change to a different scheme and click the Apply button. I see that you are in India so your dialogue box may look a little different but This is where you need to look.
I went to options preference and iam not able to find imaging and calculation option.even i went to workenvironment and check out the menu option,where iam not able to find the imaging and calculation option.
Woody
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-02-03 02:22 PM
‎2005-02-03
02:22 PM
If you are not using the US version it will look the the attached image.
You will need to apply the expert mode.
HTH.
Cheers.
Ben
HTH.
Cheers.
Ben
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-02-03 03:58 PM
‎2005-02-03
03:58 PM
If you want to keep your profile, just add the commands to the respective menus.
-Open Work Environment
-In the tree structure find Command Layout schemes/Menus
-In the 'customize Menus' tab on the right set up the columns like this:
- on the right select: Build this menu: Calculate
- On the left select: 'all commands by theme'
- then copy the required commands from the left column into the right column.
- Don't forget to save it as a scheme
Gergely Kmethy
VP, Customer Success, Graphisoft
