2006-04-18 07:20 PM - last edited on 2023-05-23 03:30 PM by Rubia Torres
2006-04-18 07:29 PM
2006-04-19 01:12 AM
2006-04-19 01:24 AM
2006-04-19 03:44 AM
2006-07-04 02:37 PM
2006-07-04 03:16 PM
Gorazd wrote:Just tried it quite a few times, with different measurements, worked every time for me. I'm working in metric, using millimeters...
Draw a vertical line, select it, then take your hand of the mouse an just type:
CRTL+SHIFT+D (copy)
ENTER (to confirm starting point)
X
100+
ENTER
This should copy a line 100 cm away of the first one.
Repeat the process several times.
Measure the distance between the lines. Some lines are not 100 cm away from the second one. This happens if I zoom out. If I move the mouse a little, or have a big zoom, distances are OK.
2006-07-04 11:29 PM
Draw a vertical line, select it, then take your hand of the mouse an just type:No it shouldn't actually. It will copy a line 100 in the X direction, because that is all you have entered. But you didn't enter anything for Y, so whatever Y was reading in your coordinate box when you hit the last enter is how far it will move in the Y direction. You must enter both X and Y. This is a good example of why you should change your method to something like this:
CRTL+SHIFT+D (copy)
X
100+
ENTER
2006-07-14 02:24 PM
