2021-08-16
07:35 PM
2023-05-25
05:51 PM
Rubia Torres
2021-08-22 08:51 PM
2021-08-27 08:55 PM
2021-08-27 09:08 PM
2021-08-29 05:11 PM - edited 2021-09-08 09:52 PM
I created a little matrix that shows how Beam Holes and Openings placed into simple rectangular Beams and Profiled Beams are displayed on the Floor Plan when they are placed above the Floor Plan Cut Plane (FPCP), cut by the (FPCP), or are below the (FPCP), with Projection set to "Symbolic" or "Projected".
In the lower half of the image, one Opening in the same Beam uses an "X" floor plan symbol, there other has no floor plan symbol.
It seems to me that if you place an Opening into the Beam, you can achieve the exact Floor Plan representation you want, and you can also Label it.
Also, the MVO Dialog has separate settings using which you can control the display of the Opening's Symbol, Axis, and Marker.
