Learn more
Objects Schedule in wrong zone
Hi All,
When generating my plumbing schedules in ArchiCAD 21, Objects are clearly showing up in the wrong zone. We have the schedule filtered by floor and room, so that all of the plumbing fixtures for bath 107 should show under that room name, etc. However, Fixtures on the other side of the building, not near Bath 107 are showing up as located in that zone. Note that this is not an issue of overlapping zones, where it is just picking the wrong one. The zones are well separated from one another. Admittedly, I copied objects from that zone and moved them to another zone, but this used to work fine. I have tried "hard updating" the schedules by closing and then reopening the files, but that did not work. Thoughts? Can an object be "assigned" to a zone? (he typed hopefully...)
0 Replies 0
