Gerri
Objects floor plan display in a Hotlinked module
Hey, everyone! I have a strange one, I think.
We had a floor plan drawn with grid elements on a different story. Then that was made into a module to be hotlinked in the same file, but the grid elements obviously showed up everywhere anew. Then the grid elements' visibility was changed, so they show up on all other floors, but not the one containing the hotlink module. After that, they were impossible to access and mend the error.
I can see this happening with other elements. Is there any way to access them, other than breaking up the module?
Thanks!
Operating system used: Windows 6003
2 Replies 2
Marc H
Hmm, did you work it out?
I’m not sure the source of the non-editable error issue, but I believe grid-lines are a project level tool. I would not include them in a module creation.
In any case, one of the main benefits of using modules is the placement in multiple locations and/or orientation, so you would want to keep grid values out of the module.
Hope this helps.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC28 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
DamianW
Hotlink modules, IMHO, should generally be published from a publisher set (along with a layer combo). turn off grids by layer before you publish and it should remove them from the HLM.
It also sounds like you aren't sure of the home storey of the grid elements either. It's not super intuitive to find and set the home storey of the grid (GS please fix) but make sure they are set to the correct/ consistent storey, regardless of how you want them to show.
HLMs set by self-linking pln files, as well as multistorey HLMs typically creates more errors, but also but has its advantages. This is one of the potential complications.
Note: you can always open MOD files in a new window to see exactly what the file contains.
