Oblique Stair
I'm drafting an as built project, and I'm having some trouble with this stairs. Does anyone has a tip for drawing it?
Dontknow
I would make it out of morphs.
But because it has to be oblique you cant pull the morph.
First draw the shape of the tree and rotate it vertically.
So I would make a frame of morphs and make the treads out of morphs or slabs.
Made a video of it.
I gave the shape of the tree no thickness.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Remember that the stair treads are always perpendicular to the baseline of the stair (new stair tool).
So create the stair so the baseline runs perpendicular to your treads and then edit she shape of the boundary of the stairs to get the shape of the flight that you require.
