Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Offset in Archicad 11
I have a big problem! I can't find offset function i new Archicad 11:( Pless Help me!
2 REPLIES 2
Stress Co_
Window> Palettes> Control Box
The Control Box may be "compacted". Right click the box and select "extended".
Marc Corney, Architect
Red Canoe Architecture, P. A.
As mentioned in another post, the coordinate and control palettes should ABSOLUTELY be on your screen by default. The tracker is no substitute.
Rex Maximilian, Honolulu, USA - www.rexmaximilian.com
ArchiCAD 28/29 (user since 3.4, 1991)
16" MacBook Pro; M4 Max (2024), 48GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
