Old AC files
lagodue
I have some AC files from 1998 that I would like to access. AC9 and 10 won't open them. Any ideas?
"Bob" - Church of the Sub-Genius
Graphisoft afficionado since 1993
Thomas Holm
AC7 (which also is available in an OSX version that even runs fine on MacIntels) should open anything as far back as AC4.5, I think.
You should be able to get a copy of AC7 from your reseller if you have a current licence. It runs with current WIBU keys.
Hopefully your file is a .pla which contains the library objects needed. Otherwise, you might get problems with any non-standard items.
Open in AC7, Save As (new name.pla) - this should make the file AC7-native.
Then Open in AC9, Save As (new name again.pln) - this should make it AC9-native.
Then Open iin AC10 or 11. Save As again.
Djordje
Look here:
http://archicad-talk.graphisoft.com/viewtopic.php?t=17884
and read the Wiki ...
Thomas is right, 7 saves your bacon.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
