rob2218
Openings - How to get drywal to wrap around?
see attached.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
Rob, AFAIK you can't. I have struggled with this one too. I believe the problem is that AC just sees the opening as a door type object.
A work around would be to end the walls on both sides of the opening and put in a separate header piece of wall above which you could set to show as overhead only with dashed lines. You will have to flip the reference line of the overhead piece of wall or it will not play nice.
Gerald Hoffman
Archicad 4.55 - 29-Latest USA
rob2218
well.....VIOLA! (sp?) I just found out from a good friend in the north east coast....you can.
Here's how.
you have to use a different opening object other than "Simple opening"
it appears theres an opening type which "does" indeed allow you to set wrap around drywall closure sizes....very slick.
i>u
Edgewater, FL!
SOFTWARE VERSION:
