Bruce
Ordering Project Map
I'm sorry if this question has been asked before, but I'm in my final 3 weeks of uni (ever)...which means my time is short and my brain is mush.
Is there a way to change how the project map is sorted? I would like to sort my details by name, but at the moment they are sorted by type, then by name.
Cheers.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
3 Replies 3
__archiben
no. unfortunately not. the ability to organise section, elevation and detail windows in the navigator would be very welcome.
you can create viewsets and drag them into the order you want?
~/archiben
b e n _ f r o s t
Bruce
Thanks Mr ben
Re: View Sets - that's the next step
Cheers.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
tsturm
Ben
There is a way to organize them.
Just remember where you created the detail from and start the number with a letter or series of letters to describe where the detail came from.
Like PLN for Plans, SE for Sections, ELV for Elevations, DTL for free floating details.
Then all the details which start with PLN will be grouped and numbered in sequence.
Note that you can change the number of the details as well. However, you can not use a number which already exists.
Also on this issue. If you are making lots of details and for some reason jumping around in the numbering sequence like 300 for sections and 600 for millwork. The detail tool will by default want to use the highest value to start the next number from no matter how you Option Click on a set number. Just keep an eye on the detail tool ID if you do not want the next number it is choosing for you. Again, you change change this number, just not to a number which exists.
HTHs
I saw somewhere before where it was you which helped to define the difference in the graphics of the details. Right??
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
