‎2016-02-04 11:42 PM
‎2016-02-05 02:39 AM
‎2016-02-05 06:10 AM
‎2016-02-05 02:29 PM
Barry wrote:Yes. You should get a double-arrow icon on any edge of the palette that will stretch the palette on a Mac.
Maybe Macs are different but in Windows we can grab any edge of the dialogue to stretch it.
We don't have to use the bottom right-hand corner.
Is this not the case on a Mac?
‎2016-02-06 12:04 AM
We don't have to use the bottom right-hand corner.Barry. The problem is that the bottom of the window gets tucked down behind whatever is at the bottom of your UI. You can't see the edge of the window at all to stretch it up. I believe it comes from adding rows to your info box or adding palettes. It shrinks up the vertical real estate to a point that you can't move a window to a position that you can see the bottom of it.
‎2016-02-06 03:23 PM
4thorns wrote:You should be able to stretch the top of the palette down (making the palette shorter in height), then move the palette up to access its bottom. Works here.We don't have to use the bottom right-hand corner.Barry. The problem is that the bottom of the window gets tucked down behind whatever is at the bottom of your UI. You can't see the edge of the window at all to stretch it up. I believe it comes from adding rows to your info box or adding palettes. It shrinks up the vertical real estate to a point that you can't move a window to a position that you can see the bottom of it.
