Origin - tracker always relative to origin
When I try to input anything in the tracker the distances are always relative to the origin. Its tremendously frustrating and not this way on other computers in the office.
When I start any line, measurement, etc. it also always tries to reference it to the origin.
How do I shut this off so the tracker is relative to the objects actual settings? (meaning if I increase the height of a wall in 3D it should be relative to its previous height, not relative to 0)
3 Replies 3
Make sure the highlighted option is selected.
See attachment!
vfrontiers
As I suspected, it is also governed by the COORDINATES BOX toggle. Check the DELTA (symbol) next to the X,Y, R,A boxes...
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
You are right about the delta symbol. That fixed it. Thank you very much!
