Overlapping title blocks
Hi there,
Why do my title blocks overlap each other in my floor plan? For example, in my floor plan, my 2nd floor title block seems to overlap my 2nd flr. title block. I set each one to Show On Current Story Only in the settings box, so I'm not sure where I'm going wrong. I'm using Drawing Block Title NCS.
Thanks,
Scott
4 Replies 4
TomWaltz
southpaw wrote:
Hi there,
Want to try that sentence again? The 2nd floor overlaps the 2nd floor?
Tom Waltz
Yikes! I meant to say that the title block for my 2nd floor overlaps the title block for my 1st floor.
Thanks,
Scott B.
TomWaltz
Thanks,
Scott B.
OK, I thought it might be something like that.
You have each object on separate stories, but for some reason one is appearing on a story you do not expect?
My first suspicion is that one of them accidentally got its "Show on Story" setting changed.
My second thought is more of a usage issue: I usually recommend that title blocks go in Plotmaker, not in Archicad.
Tom Waltz
Djordje
First time I hear that PlotMaker has floors ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
