Chris Grantham
Oversize Surface Mount Sliding Door Panel
Is there a quick way to change the size of a surface mount sliding door independently of the opening? I want the door to have some overlap on either side of the opening... I know I can create a custom panel and empty opening, but I am wondering if I am missing something easy in the actual object. Thanks!
-Chris
16" MacBook Pro M1 Max
Mac OS 26
ArchiCAD 27 Build 6010
6 Replies 6
Chazz
Easily done --in Cadimage Door & WindowBuilder. Not sure how doable it is with the standard library door objects. I have not used them in a decade.....
Nattering nabob of negativism
Chris Grantham
Thanks for the response. It sorta irks me that everything is "easily done" in with some sort of add-on that costs $500 or more.
Mac OS 26
Chazz
I hear you. It's always something.
However, there's a few things I feel are worth spending some cabbage on to make your AC experience a pleasant one. For me they are:
  • 1) Door & Window Builder
    2) Stairbuilder
    3) Artlantis Render
    4) BaseCamp
    5) Objective
    5.5) Internet Radio (long live KEXP!)
    6) A really nice monitor (loving this Thunderbolt 27")
I know that's a lot of cabbage but you're a pro, right? Try to forget that you spent $5K on the software and subscription....
Chris Grantham
We've been using Evernote instead of Basecamp. I have the monitor and artlantis, and internet radio. Long live KCRW!
Mac OS 26
Chazz
I'll check out Evernote. And I do love it when my morning becomes eclectic
I agree that paying 10% of a license cost for a pair of door/window objects seems excessive. I'm still doing a trial of the Cadimage product and while it has some impressive flexibility compared to the US AC doors/windows, it is missing some important US features for casing/trim sizing and wall insertion modes. And, you build every window/door from scratch - the first time, anyway: there is not a library of default types, but rather a single object that can morph into most (but not all) desired types. You trade one set of limitations for another, it seems to me.
A workaround for the panel limitation in the US library: for the door panel style, choose "Empty". This will give you a cased opening, less the sliding panel. Create your own panel with the modeling tool of your choice. No track / hardware is modeled in the US part in any case - just a door slab - so you can make this externally hung door more realistic by using a simple profiled element to model the track, etc.
(You cannot create a 'custom' panel with the AC lib to achieve your goal of an oversized panel, as the custom panel will be deformed to fit the standard panel size.)
