PLN and PMK exchange betw. AC9 and AC10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2006-05-24 06:17 PM
How can I import Titles from AC9 and how can I make my own titles for layouts with AC10?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-06-05 03:34 PM
There is a 9-migration work environment on the 10 US Library update page. If you have the US version, go to the Help menu in 10, Check for Library Updates.... and you'll find a link there to an updated startup template for 10 as well as this optional Work Environment, which offers the old shortcut keys (ctrl-3 for 3D, for example) to help with the transition.
Karl
_________________
Karl Ottenstein - Archispectives LLC
AC 10 US(817), Artlantis R, Adobe CS2, Piranesi 4, SketchUp 5, etc.
XP Pro SP2 / OS 10.3.9
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-06-05 03:50 PM
So I spoke somewhat too soon, I can see the NCS Drawing title 10, simple title 10 and title with layout no 10 when I start a new file in 10, however, I was in a file I had updated from 9 so all the titles we made showed up but no NCS, etc. When I go to load other title, I can't find the NCS title anywhere. If its part of the library container, why doesn't it show up already, and if its not inthe library container, why can't I find it to load it?
massachusetts, usa
AC25 (1413), since AC6
Windows 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-06-05 03:59 PM
I had to extract the standard object library to a new folder in order to find the title types that are inside. If they are in the loaded library why couldn't I see them from the title type dialog. This just does not make any sense. Now to start working with them, that should be another adventure. Why is it that sometimes the simplest thing is so difficult?
massachusetts, usa
Windows 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-06-05 04:23 PM
kevin wrote:I have not looked at them, but if they do not show up in the Titles dialog, it's possible that they are simple objects, not actual Titles.
So I found them but this is really stupid.
Check what their SubType is to find out.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-06-05 04:26 PM
massachusetts, usa
Windows 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-06-06 10:10 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-06-06 10:21 PM
So I found them but this is really stupid.And here is the continuation of the insanity, you can then delete the extracted folder and they are still in the list.
massachusetts, usa
Windows 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-06-06 10:35 PM
I have the titles when I use the template but not any other time.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-06-06 11:11 PM
This was brought to you by the Graphisoft Intuitive Interface Department. I saw a russian bootleg of AC11 and the titles should be much easier to handle. They are going to be on a floppy disk, frozen in a block of ice, locked in a safe, wrapped in chains located at the bottom of the ocean, the location of which is only available on a map you can find using ResEdit while standing on your head.
All of this was on a MAC, PCs may vary.
massachusetts, usa
Windows 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-06-06 11:34 PM
