Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
PLN icons not looking like they should?
rob2218
see attached.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
2 REPLIES 2
Have a look in your Archicad program folder and you should find a folder called "Graphisoft Shell Extension".
C:\Program Files\Graphisoft\ArchiCAD 18\GRAPHISOFT Shell Extension
Double click the "Register.bat" file that you will find in there.
This will briefly run a small command prompt window.
You may need to restart your machine but it should now register a PLN with Archicad.
rob2218
thanks sir!....Barry.
that did it.
how you guys know these things....I'll never figure it out.
šŸ˜‰
i>u
Edgewater, FL!
SOFTWARE VERSION:
