2020-01-20 10:13 PM
2020-01-21 09:42 AM
2020-01-21 10:17 AM
Christophe wrote:
You are able to disable surface transparency by the option at the right bottom of the surface parameters.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 5900X | 32GB | GTX2080TI |
2020-01-21 12:25 PM
2020-01-21 06:22 PM
Einstein96 wrote:Unfortunately, the alpha channel is not used. The Figure Tool's transparency option simply makes 100% white pixels transparent.
Hi!
Is there any way to import an image/picture with transparency or to set transparency of an imported image/picture? I mean, in 2D views, not in rendering.
I imported a PNG image to my plan (tried also with worksheet), ticked "Transparent" in its properties but it only shows 2-bit transparency, so: 100% transparent or 100% opaque. My image has many levels of opacity but it looks like full information about aplha channel is not read in AC.
Or maybe there's some trick to do it?
