Panning with Mouse in Lion OSX
Hi All,
I just updated to Lion, everything seems to be working fine, but I lost the ability to pan with the mouse. I added a keyboard shortcut for pan, but i really cannot work without the mouse enabled pan. Anyone know the solution for this issue?
Thanks.
Don
4 Replies 4
Eduardo Rolon
If you have a Magic Mouse I recommend this:
http://www.bettertouchtool.net/
For all other mice I like:
http://plentycom.jp/en/steermouse/
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
If you're using the Magic Mouse, you might also try MagicPrefs
Because the Magic Mouse is a full touch surface, you can add as many different combinations of clicks, taps, and swipes as you please.
Ralph Wessel BArch
Central Innovation
Katalin Takacs
Here you can find the steps of enabling the pan function of a Magic Mouse, if you have one: http://archicadwiki.com/MagicMouse
Katalin Takacs
Thanks all - problem solved.
