homayon wrote:
Hey every one.
I wonder that it's possible to do parametric design with archicad? And where can i find tutorials?
Here is an example i found.
www.egodesign.ca/_files/articles/blocks/2926_toronto_tower_rojkind.jpg
Thank you for helping
Ok - 'parametric' is a very broad term - but I assume you mean 'generative design' (which is parametric in nature). The building skin may have been created this way but if so that is not Archicad territory - unlike tools like
grasshopper
Having said that you could model that many many different ways, including in AC if you wanted to - but you might be bald at the end of it.
You would be better off modeling the skin outside of AC and then bringing it in. Ironically you might use some sort of parametric tools to create it (parametric form/history-wise from that 3d software's point of view) but when it arrives in AC it will be 'dumb' (from AC's 'parametric' modeling point of view ) ... so yes,
parametric is a broad term.
