Parapet Coping how to...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2007-02-08
05:38 PM
‎2023-05-23
05:11 PM
Rubia Torres
Is there a way to make a stone profile to do what is shown in the attached image by using Complex Profiles or is there another way (sweep, Object, etc.)
I'm new so speak slowly...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-02-08 07:52 PM
The easiest way is to make a profile and apply that on beam tools. But there could be some trouble to make the horizontal piece to connect correct to the angled beam. Try and se if it works for you.
Another easy way is to buy for example "3d profiler tool" from Cadimage.
Self I would build a GDL object that could do this thing, but this object is not the easiest object to do if you aren't familiar with GDL-language.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-02-09 01:32 AM
Beams can be inclined in ArchiCAD 10. Hopefully that is the version you are using.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-02-09 03:06 AM
laszlonagy wrote:Unfortunately inclined beams dont mitre in the vertical plane (retain vertical end face). SEO can be used to clean up the join but is messy as a number of operations are required
Create a Complex Beam.
OSX 10.15.6 [Catalina] : Archicad 22 : 15" MacBook Pro 2019 [/size]
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-02-09 10:11 AM
Aussie wrote:The coping shown should miter at equal angles (as the beams do automatically) not vertically. This is not like a cornice to rake miter that does require a vertical miter (with SEOs and custom profiles to make a proper joint). It would seem strange to have a different coping profile for the sloping part that would be required for the vertical joint.laszlonagy wrote:Unfortunately inclined beams dont mitre in the vertical plane (retain vertical end face). SEO can be used to clean up the join but is messy as a number of operations are required
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-02-10 12:49 AM
Matthew wrote:Aussie wrote:The coping shown should miter at equal angles (as the beams do automatically) not vertically. This is not like a cornice to rake miter that does require a vertical miter (with SEOs and custom profiles to make a proper joint). It would seem strange to have a different coping profile for the sloping part that would be required for the vertical joint.laszlonagy wrote:Unfortunately inclined beams dont mitre in the vertical plane (retain vertical end face). SEO can be used to clean up the join but is messy as a number of operations are required
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Visit the website to download a trial version.
www.encina.co.uk
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-02-10 02:36 AM
Aussie wrote:Unless I am not understanding you, I have found that angled beams do miter in x/y/z correctly as long as the profile is appropriate to the function. It's just conditions like classical rake/cornice joints that require special attention.Matthew wrote:Aussie wrote:The coping shown should miter at equal angles (as the beams do automatically) not vertically. This is not like a cornice to rake miter that does require a vertical miter (with SEOs and custom profiles to make a proper joint). It would seem strange to have a different coping profile for the sloping part that would be required for the vertical joint.
Unfortunately inclined beams dont mitre in the vertical plane (retain vertical end face). SEO can be used to clean up the join but is messy as a number of operations are requiredI wasnt suggesting that the beams join along a vertical plane but that mitres dont work in the Z direction as distinct from the x/y plane
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-02-10 03:17 AM
Matthew wrote:hmmmm. I must be missing something as the ends of the beams are always vertical for me.
Im talking about a custom profile with two beams end on end and one angled.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-02-10 03:25 AM
