David Bearss
Partial Structure Display
Supposed to be under;
Document > Partial Structure Display
But it does not exist in my menu. Is there a secret to enabling this?
David Bearss
Archicad 28/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
5 Replies 5
Are you using a custom Work Environment.
If so then it may not be included in your menus - you can add it if you want to.
Or switch to a standard Work Environment.
In 18 I always had the Quick Option palette open and docked and accessed it from there.
David Bearss
Quick Options! That's where it is. Thanks I had completely forgotten about that.
Thanks!
David Bearss
Alienware 17 R5
And it is also in the Options Bar at the bottom of your Tab, along with all the other View Settings.
Nowadays, I do not even have the "Quick Options" Palette displayed because everything is accessible from the Options Bar.
David is using version 18 (I checked this in a post with him a few days ago), so his only option is the quick options palette.
Ooops, OK.
