2004-02-28
08:52 PM
2023-05-26
03:28 PM
Rubia Torres
2004-03-01 06:40 AM
2004-03-01 07:15 AM
vfrontiers wrote:Duane you can export a PDF from preview to most formats
The only saving grace was Print2PICTon MAC (not available for OsX) and something I found for WinXP called e.peernet driver. I will look up the specs tomorrow at the office. but it is just what Print2PICT is but can save in ANY format conceiveable.
2004-03-01 08:00 AM
Aussie wrote:This would be fine if PlotMaker could import PDF.
2004-03-01 08:05 AM
Aussie wrote:I suppose I was hinting that this requires not only an extra step, but an extra FILE for each set of notes.... just cumbersome...vfrontiers wrote:Duane you can export a PDF from preview to most formats
2004-03-02 03:08 AM
2004-03-02 04:28 AM
Matthew wrote:Aussie wrote:This would be fine if PlotMaker could import PDF.
2004-03-02 06:55 PM
Aussie wrote:Unless something has changed recently the quality on these other formats is inadequate for text.Matthew wrote:Aussie wrote:This would be fine if PlotMaker could import PDF.
What I meant was Preview can export the PDF file to different formats which can then be imported into PM
2004-03-02 10:14 PM
Matthew wrote:Change the page setup to around 200% (use a large page format) when creating the PDF. Any exported PNG/jpg can be shrunk when importing into PM to get a good resolution
2004-03-04 04:28 PM
