Pasting text from Word X
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2004-02-28
08:52 PM
- last edited on
2023-05-26
03:28 PM
by
Rubia Torres
Anybody else experiencing this?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-03-01 06:40 AM
OLE is crap.
Cut & Paste is OLE.
The only saving grace was Print2PICTon MAC (not available for OsX) and something I found for WinXP called e.peernet driver. I will look up the specs tomorrow at the office. but it is just what Print2PICT is but can save in ANY format conceiveable.
It's a bit pricey at around $90... and you still have to produce in Word / Excel and print. That same SINGLE SHEET printing crap applies as well.
Here's hoping [or rather "wishing"] for ACv9.0
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-03-01 07:15 AM
vfrontiers wrote:Duane you can export a PDF from preview to most formats
OSX 10.15.6 [Catalina] : Archicad 22 : 15" MacBook Pro 2019 [/size]
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-03-01 08:00 AM
Aussie wrote:This would be fine if PlotMaker could import PDF.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-03-01 08:05 AM
Aussie wrote:I suppose I was hinting that this requires not only an extra step, but an extra FILE for each set of notes.... just cumbersome...vfrontiers wrote:Duane you can export a PDF from preview to most formats
Visual Frontiers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-03-02 03:08 AM
Using the Mac in OS X.2.8, I do it as follows.
Press down on Cmd+Ctrl+Shift+4.
This will give you a screen shot saved to your clipboard which can then be pasted into your file.
Just crop the area you want to use. No second files, No other drivers to deal with using or buying.
True, the resolution is not 200 dpi. The job is done though.
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-03-02 04:28 AM
Matthew wrote:Aussie wrote:This would be fine if PlotMaker could import PDF.
What I meant was Preview can export the PDF file to different formats which can then be imported into PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-03-02 06:55 PM
Aussie wrote:Unless something has changed recently the quality on these other formats is inadequate for text.Matthew wrote:Aussie wrote:This would be fine if PlotMaker could import PDF.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-03-02 10:14 PM
Matthew wrote:Change the page setup to around 200% (use a large page format) when creating the PDF. Any exported PNG/jpg can be shrunk when importing into PM to get a good resolution
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-03-04 04:28 PM
Rec#'s
700
666
352
Jeffry Covarrubias
GS US Technical Support Team Leader
P-C2D 1.86GHz/2GB w/ 256MB GeForce 8600GTS; G4 OS 10.4.10 1GHz/1GB "[that other software] is a fancy set of electronic marker pens"
