Path of new/edited objects is invisible
duduardo
Hi!
I just bought a 16 inch MBP with M1 Pro. After downloading Archicad I noticed that when I want to create or edit a wall (could be any. other object) the black lines that would show you where that wall will be created or how they would be edited, I can't see them. If I click, sure thing the wall creates to te point clicked.
I noticed that the only way I can see the path is to hover over the pop-up menu (Image 2) and then I can see. In case there is a need for more info I can provide.
I would be grateful if anyone could help me.
Operating system used: Mac Apple Silicon 15 Sequoia
4 REPLIES 4
What version of Archicad?
Is it the latest build?
There was another post I remember that was similar for Archicad 26.
But installing the latest update fixed that.
https://community.graphisoft.com/t5/Modeling/Visual-Feeback-live-preview-disabled-a-bug/m-p/634145/h...
Hello!
Thanks for your response, the Build is 3001 INT. Thanks for the link, seems we have the same problem. I will try to update Archicad.
Thank you again!
I have un-marked it as a solution until you confirm that an update does indeed fix the problem.
I am assuming you are using version 27?
(Just a note… the behavior that you are not seeing is called “rubber banding”.  Will be interesting to see if this is a Sequoia issue.)
One of the forum moderators
Setup info provided by author
