Pen of Shadow Contours
Does anyone know if the pen used for shadow contours in 3D (when you have "Contours On" for "Vectorial Sun Shadows" in "3D Window Settings") is able to be modified anywhere or is it set as default to pen 1?
Link
Not AFAIK.
You can apply another penset though, changing pen 1 to something else.
Link.
Thanks Link,
Yes, that's what I ended up doing. But it's not that flexible, in that if you have elements in your model also using pen 1 (which you invariably do), you can't set the colour and thickness of them separately.
