You can start a new project with default settings.
In that file the GDL Objects should appear with their default settings when placed.
Then copy-paste one such instance from that file to your other file where you modified the settings.
Then use parameter transfer (ALT-Click + CTRL-ALT-Click) to inject the parameters of the copy-pasted GDL Objects to the modified objects.
