Stuart Smith
s/e markers show incorrect drawing reference on layouts
I am having a serious issue with some section/elevation markers referencing the wrong drawings. The really weird thing is that they show correctly in the saved plan view (2D window), but when that view is placed on a Layout, the marker reference changes! See attached screen caps.
The marker is a custom part, but has been in use for years without issue.
Any thoughts?
AC user since 8.1
David Maudlin
Stuart:
One thing to look at is to select the marker, open its settings dialog box, under the General panel click on the Browse... button and check which drawing the section is referring to.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Stuart Smith
Looks like I fixed it. There was some legacy GDL logic in the marker part which seems to be the culprit.
AC user since 8.1
