2011-11-21 08:31 PM
2011-11-22 02:52 AM
Steve wrote:You could set this pen thickness to zero (0 mm) to keep your pen number / pen size idea consistent.
I set column 10 to .01 mm so I have a hairline in each color as well.
2011-11-22 03:20 AM
2011-11-22 04:07 PM
2011-11-23 02:14 AM
rob2218 wrote:Graphisoft may be happy that the lights and lavatory objects use the same pen colour.
The light objects use PEN NO.4....the lavatory objects use PEN NO.4....as well......why they were programmed like, why the GS programmers didn't just separate and assign objects with different pens is beyond me but.....it's a hassle to say the least.
rob2218 wrote:The only options (I can think of) that you have are:
I need a solution for when you insert an object out of the box with a certain pen number....in this case pen 4....that is not the same pen number as another object.
