Perforated wall
Hi there. It's my first post here, so welcome everybody.
I know that there where some topics about perforated wall before but mine is a little bit different. I would like to have a perforation of a similar shape to the attached pattern.
I'm just wondering if there is any easier way than doing it by a complex profile. I've recently done a perforated wall with random holes using complex profile, but this time would like to have more precise pattern. That's a pity that you can not use image reference in complex profile.
Is that the only way of doing this, or maybe it would be easier to make a perforation in Artlantis or any similar program.
I will be glad for any tips, I've just begun with Archicad so I am totally confused. Thanks!
Dwight
If you can't get the image in a vector format, your only option is to manually trace it on the floor plan and copy the fill into the complex profile.
Dwight Atkinson
Dwight
You CAN use the image as a mask, but this will not show in analytical views.
Create an alpha channel [in a photo editor] over the transparent areas and map the image to the wall surface as a material.
You'll also need to use the ALign 3D Texture to make it line up as you want.
Dwight Atkinson
