Physical Sky, not showing up when l render.
I have just switched to Archicad 19. When l go to render the chosen physical sky doesn't show. I am using the same settings that l was using in 18 (which was working well). Does anyone know how l can fix this?
1 REPLY 1
It would be helpful to see the rendering you got and the openGL view.
Was this a migrated project or new from AC19?
Are you using a detailed settings or one of the defaults?
Under the detailed box make sure the visibility boxes are checked.
Try reverting to a default rendering style to see if the sky comes back.
