2006-05-04
09:42 PM
- last edited on
2023-05-23
05:16 PM
by
Rubia Torres
2006-05-04 09:49 PM
2006-05-04 10:11 PM
2006-05-04 10:21 PM
Sergio wrote:Use a blank line by modefinf a Dot Line Type.
...With columns you would see the lines.......?
2006-05-04 10:29 PM
2006-05-04 10:33 PM
Sergio wrote:Are your columns set to clean with the wall? What lines are you seeing?
I was trying to have it display as a truer monolithic construction. With columns you would see the lines. Less of a problem in the grand scheme of things, I suppose. Time to change all of them....
2006-05-05 12:08 AM
TomWaltz wrote:The lines that appear when... columns don't clean with the wall...?
I've routinely used columns for pilasters just because they clean up well with walls and can have skins "wrap" around them,I noticed the "Lesene" thingamabob object in my stroll through the library, and I just assumed that since it looked like it did what I was looking for, that it would be the ONLY thing that would work. Thanks guys for opening my eyes... (kinda bright out here though)...
