β2006-10-05
08:17 AM
β2023-05-23
03:25 PM
Rubia Torres
β2006-10-05 02:29 PM
β2006-10-05 03:22 PM
β2006-10-05 03:42 PM
laszlonagy wrote:There are no Stupid Questions ...Right?
Tom, here is the link to that trick you mentioned:
http://www.archicadwiki.com/TechNotes/Multi-story_Hotlinks?highlight=%28module%29
β2006-10-05 04:22 PM
Jay wrote:I did this and actually there are 3 files.laszlonagy wrote:There are no Stupid Questions ...Right?
Well. I did not understand the relationships between the Skyscraper Module Files and the "Mother" File. Like in Step 3 & 4, which file are these step performed in.
Lets say that I have a Residence (File name "House") that contains the Following Stories:
3. Third Floor
2. Second Floor
1. First Floor
-1. Pony Walls
-2. Foundation
-3. Datum
I would like to Hotlink all the Stories Except Datum to an other File called "Site".
Could someone explain the steps.
Jay
β2006-10-05 05:10 PM
laszlonagy wrote:I take it you mean name the saved file as and overwrite file B?
In the upcoming Dialog, you must check the Change to hotlink to the saved file checkbox and overwrite the module file.
β2006-10-05 05:14 PM
β2006-10-06 05:21 AM
β2006-10-07 09:10 PM
Link wrote:
This is a great method and is pretty much the same thing that Eric Batte came up with back in the Escribe days. He called it Circular hotlinking. To quote Eric:
This may not be obvious to everyone, but it's a little technique I presented to the office the other day: Hotlinking modules to themselves (circular hotlinking, I'm calling it).
We keep all project info. within a single PLN file and since we often have a different rotation on the site plan (on paper) we draw the site on the story below the floor plan (of the building). As some of you may have noticed, if you draw at one orientation and choose to rotate the PMK in PlotMaker you can end up with upside down text and other elements. It is possible to use hotlinked modules to link to another story of the same PLN file. So, if we go to the site story we can add a hotlinked module pointing to the same PLN file and place the building story on the site story and vice versa.
MODEL.PLN (story 1)->linked to->MODEL.PLN (story -1)
Now, an important thing to realize is that since you are linking to the same file you're working with the hotlink of the other story will not be recognized as updated until you save the file. So the process to update the hotlink is to save the file and then update the hotlink manually.
This allows us to draw within our drawing bounds for each plan and as we prefer the rotation to be for each project to best fit on the sheet in PlotMaker. It could also be used to link the roof story to the site or anything else you could think of.
Eric Batte
Be Productive. Be Efficient. Be Standardized.
The Standardized Template System for ArchiCAD
www.getstandardized.com
It's just a different slant on the same idea, really. But it is under-utilized IMHO - it's really quite powerful!
Link.
β2006-10-10 04:01 AM
