Placing jpegs of paintings
I am trying to place jpegs of paintings in the model. I use the jpeg as a material and place it on a wall tool to create the canvas. However, the image is static and does not move when I move the painting (wall). The effect is a tiling of the jpeg on the painting (wall). How can I make the entire image move with the canvas?
1 REPLY 1
Dwight
From 3D window:
Design>Align 3D texture>Set Origin
then click in 3D window to set origin.
You can also load the image in your library and then access it from the object: Picture 16
This will be better than using it as a material.
Dwight Atkinson
