Plaster thickness
How do I add plaster thickness to walls I create in ArchiCAD?
is their a ready object in the library, which I can use to create plaster thickness on brick masonry?
3 Replies 3
1.Options > Element Attributes> Composites>brick plastered one side - Create
2.Select Walls > Wall Selection settings>Structure >Cut Fill - brick plastered one side>OK
Rod Jurich
A picture to help Rajesh
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Many thanks! I will try it out today!
