Plot Maker 9
Is there an easy way of changing Master Drawing from sheet 3X2 to 17x11
Basically I have made new master with a sheet 17X11 and imported drawing from Master 3x2 and the option strertch is not available
Please Help
Thanks
21 REPLIES 21
Have you tried taking it into archicad and resizing? Might work!
The only reason I can think of for the Stretch command not being available to you if you are trying to do what I think you are trying to do would be if you forgot to suspend groups first.
woodster
Erika Epstein
stretch ctrl/cmd H is available in plotmaker
resize cctrl/cmd K is not available in plotmaker
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
to be more specific i took templet from the sheet 3'x2' and inserted into 17"x11" sheet.
see picture.
so now i am trying to fit that into the page.
Thanks
You CAN stretch all the line work here if, as I mentioned earlier, you suspend groups. The Stretch command will NOT be available to you unless you have suspended groups. That being said, you will still have to deal with all the text items separately.
woodster
Thank you all
Link
I usually copy & paste into ArchiCAD and resize there. It's a bit of a pain, because curves and text spak out, but it's still the fastest way to resize IME.
Link.
Ben Odonnell
What if you save out a PMK and then edit, copy & paste from the PMK.
Would that work instead of having to go back into ArchiCAD?
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobjectĀ®
Get your BIM objects from bimobject.com
Hey, Link; nice article in the February issue of "Envisions"
http://www.graphisoft.com/community/envisions/2005_02_link.html
Congratulations!
woodster
