Plot Maker Problem
hi guys, i have a bit of a problem, my computer has recently messed up.. so i am using my old computer and using ARCHICAD 9 and the problem is it has a seperate PLLOT system...
i am confused, beacuase i am not too sure how u send a ELEVATION/SECTION to plot maker... it does not seem to work!!
Could some one please help me... the sooner the better.. thank you all very much!!!!
Kaju
It sounds like you usually use AC10, but are on 9 for some reason.
The difference is that you simply save your project file (PLN) which has your elevations etc defined as views in the view map, similar to AC10, then in PM place your elevation view in a layout refering to the PLN file as the source, saving PLN and updating in PM as changes are made.
Does this make sense?
(Some people (a minority I would think) still created PMK files and placed them in PM, but I found that unnecessary in AC9. A leftover from earlier versions)
